I finally got to Test Drive one (Some comparisons to my Camaro)
I actually like the brakes like that hopefully it stays that way.
I honestly will probably not be a fan of that but I didn't notice it on the test drive but also the car was a non plus with the smaller dash screen.
Smaller screen honestly probably better if they didn’t make it look goofy with the plastic surround. The wheel blocks the time and temp in the upper corners and the fuel gauge and mode in the bottom corners along with other things depending on how you adjust the wheel(on the larger IC).
Yeah 100% agree with this. That shroud is goofy as hell, and you get to say you have the larger screen-- but otherwise the smaller one is probably better.
If they made a better UI to make use of the larger screen it could be just as good if not better.
Finally got the steering wheel adjusted to where I can see it now. Later RJD
