Post 11............
I would bet the steering wheel has to come off... I took a wheel off on a 2010 car to change out a turn signal stalk. Don't do this unless you really know what you're doing. Clock springs are fragile and finicky, and air bags are terrifying to handle.Good question but how much of a install would they be if they are available through dodge. later RJD
My 2014 Cadillac V had buttons? (if it's the right car), and I replaced them with paddles. They had to be mounted in these little detents held by two dimples. It was not worth the stress of breaking something. On my older Chargers, I only used manual mode on Tail of the Dragon, so I'm ok with leaving them alone.I would bet the steering wheel has to come off... I took a wheel off on a 2010 car to change out a turn signal stalk. Don't do this unless you really know what you're doing. Clock springs are fragile and finicky, and air bags are terrifying to handle.
That said, it's a neat idea to swap for the superbee ones and it might work. Just have a pro do it if the wheel has to come off.
