Rides kinda rough
sengli9
Northern Indiana
I like the car, but after 1k miles on my new the charger , this car does ride pretty rough. I dont modify things anymore, so there is no way I am tinkering with the suspension. Just making an overall observation on the ride quality.
Yeah, like the 392 w/o the adjustable suspension. I have the 305's and have been lowering the pressures a little at a time and it seems to help. They're at 30 cold and still heat up enough after driving so I should be ok.
yes the suspension is stiff plus the tires are a little harsher also RJD
Personally I don't notice much difference between the previous model Charger, but if it's a real problem for you and you don't wanna touch suspension, then it may help to get a higher ratio tire? More sidewall so it would have more rubber on it and a little higher ride height. There's plenty of room in the wheel well for an extra inch diameter of rubber. You would just have to have someone adjust the speedometer for you.
I think they also sell tires that are softer compounds, but I'd bet they wear faster.
I'm not a pro in this area, just sharing my two cents.
So these scat cack cars, arent they supposed to have the two way shocks on them? Mine is a scat pack, plus car.
If you read your window sticker it says car equipped with Performance suspension which will have a harsher ride than what your use to but also better handling . RJD
