797 Intake V2 W/ Compatible Catch Can & some more info on other products
Nick7973
Supporting Vendor 🛒
Bensalem, PA
Hey Guys,
These are not by any means the "HUGE" Parts I was referring to coming out. But small things we are working to improve in the background.
As this platform expands it makes more sense to continue to play with this platform.
We are getting ready to launch to market a catch can system that will be affordable and work with our intake as well as some other cold air intakes. So far confirmed with 797 V1 Intake and V2 Intake as well as Leg Maker.
What you are seeing here is a 3D Printed Bracket, this will be a billet bracket final design may change as well as the hose will be a higher quality PCV rated Hose(Possibly braided depending on feed back).
Target is $250 on the Catch Can Kit, no engine cover modification required.
Intake pricing won't change but we did lose our original contact who was producing our old tubes so we found a local company who can do plastic molding for us, what you are seeing here is still a 3D printed tube just a bit larger & a design change and what we found as a tiny bit more free flowing & larger air filter. And we will be offering filter socks with the new filter as well as we know some peoples go to wouldn't be a green air filter but the brand we chose to work with is a bit more local (Green Filter).
I have a set of lowering springs That should be LOWER than everything out there arriving on Friday. We will test fit and I will get some photos up. I know this isn't like ground breaking news but just know we are all still working in the background to get mods and improvements out for this platform.
Coolant res cover possibly coming and a JB4 Mount for the Engine bay so they can be mounted securely.
Yeah, is it?
Before I buy any mod, I look for written instructions or YouTube videos before purchasing, just like I’ve been doing for my other Dodge.
The install looks as if it will be quite simple - effectively install a bracket, remove old hoses, add new hoses, attach can. To me, the larger "install" complexity is that it seems to require an air intake kit installed first.
