AWD disconnect and error message
Sorry, I meant to type this car is awesome! Anyway, I love the car, it’s new and advanced so things can happen sometimes. But I am not worried. No way am I trading it out. My first car was a 1974 Dodge Dart with a 318. And while it was easy to work on, I’m not going back to it ha ha! Anyway, thank you for your interest in this thread. I’m enjoying the forum.
Recently I got an error message on the dash screen to “Service AWD.” It stayed on for 2 days then went away and did not come back. I’m thinking this is weird because the car is new and has so few miles. Well, then I a notice random vibration sound coming from the front axle every so often. Lasted about 2 seconds each time it happened. Usually on mild acceleration or deceleration. Maybe 7-10 times in a 30 minute drive. Decided to turn the car to RWD only and the vibration sounds stopped. Took it to the dealer and they confirmed the AWD disconnect was defective and will be replaced under warranty. Just wanted to pass this along.
I'm with daperry as far as batteries being an issue. I asked Gemini if car battery capacity has been keeping up with the demands late model cars. Here is Gemini's response:
"12V batteries have become the single biggest weak spot in modern cars, often failing after just 2 to 3 years compared to the 5 to 7 years drivers used to expect.
While battery tech improved modestly, the electrical demands placed on that single 12-volt box have skyrocketed, creating a real mismatch.
Why Batteries Are Struggling to Keep Up
• Constant "Vampire" Drain: Even when parked and locked, modern cars stay partially awake. Telematics (cellular modems for app remote start), passive keyless entry antennas, anti-theft sensors, and over-the-air (OTA) software updates pull continuous parasitic current.
• Short-Trip Deficits: A modern vehicle can pull 100+ amps just waking up its computers, fuel pumps, and screens before the engine even turns over. If you only drive 10 to 15 minutes at a time, the alternator barely replaces the energy used to start the car, leaving the battery perpetually undercharged.
• Smart Charging Systems: To squeeze out extra fuel economy and lower emissions, modern alternators no longer charge the battery to 100% all the time. Instead, they often hold the battery around 80% state-of-charge—which accelerates sulfation (internal wear) in lead-acid batteries.
• The EV Paradox: Ironically, electric vehicles are even harder on 12V batteries. Even though an EV has a massive main battery pack, a tiny 12V battery still powers the computers, door locks, and safety relays—and if it dies, the entire car is bricked.
How Automakers Are Trying to Fix It
Because traditional 12V lead-acid architecture is hitting its physical limit, the industry is actively shifting away from it:
• 12V Lithium-Ion (LiFePO4): Brands like Tesla, Hyundai/Kia, and Porsche have started replacing lead-acid 12V batteries with lightweight lithium packs managed by smart computer relays that automatically disconnect if the charge drops too low.
• 48-Volt Architecture: Following Cybertruck's move to a 48V low-voltage system, more automakers are transitioning away from 12V entirely, since higher voltage delivers four times the power through thinner, lighter wires."
I sure hope better batteries can be developed, as long as they're not (explosion prone) Li-Po batteries.
It is a known fact hat the 12 volt battery life expediency is about 4 years. Now you have an additional smaller 12 battery that operates all interior electronics including the S/S mode. This the battery that is failing quit often. So your observations are not totally correct. Once they get the better smaller batteries things will improve till they come up with a better alternative. RJD
We all have the AGM now as opposed to flooded batteries anyways. Since the '25 - '26 Rans had the same issue, I'll start researching there also. Speaking of batteries, my new auxiliary one won't even fully charge, so I guess I'll be going back. Dodge Case Management will be involved when I drop it off this time.
As Mentioned they got a bad batch of batteries. You should be checking it after it's installed while at the dealer. They may be AGM but they still only last about 4 years. RJD
