AWD disconnect and error message
gil3
N. Cal.
Recently I got an error message on the dash screen to “Service AWD.” It stayed on for 2 days then went away and did not come back. I’m thinking this is weird because the car is new and has so few miles. Well, then I a notice random vibration sound coming from the front axle every so often. Lasted about 2 seconds each time it happened. Usually on mild acceleration or deceleration. Maybe 7-10 times in a 30 minute drive. Decided to turn the car to RWD only and the vibration sounds stopped. Took it to the dealer and they confirmed the AWD disconnect was defective and will be replaced under warranty. Just wanted to pass this along.
December 2025 build date. Bought it off the lot. It had sat on the lot quite some time before I purchased. I’ll be sure to update this thread after the fix is done.
Hi there! If you continue to experience this and need our support, please send us a private message here.
Thanks for sharing. This is something I haven't read about here. Hope everything goes well.
I like that you received the warning. However, the fact that the "Service AWD" disappeared and there was still a problem with the AWD disconnect is not good. That message should remain until it's fixed or cleared by the service center.
I wonder if they did that big April update which a LOT of them needed.
A quick update: after replacing the defective AWD disconnect the tech took the car on a test drive and the “Sercive AWD” message came back on. Ugh. So they are looking into it again. Will keep everyone posted.
Dang! Yeah, I've never seen that here before either.
I have received the same message one time and it went away after the vehicle was turned off for a while and restarted. That was about 3 weeks ago, and the message has not returned. Hope it does not come back, but if so, I will be contacting the dealer for a fix. I have had mine since April 2026, and it is a fully loaded Scat Pack Plus. I love the car but wish Dodge would have spent more time during the buildout of these and troubleshooting of any gremlins. In contrast my 2012 Charger R/T fully loaded had virtually no issues whatsoever and it has been driven over 100 thousand miles. My hope is that this new Charger will be a good one and not plagued by issues forever and a day!
Since SO much is controlled by voltage, anyone else like me if these issues could be battery related? Considering they replace parts, and it doesn't fix it, it makes me wonder. It's bad that there is absolutely NO info out there on these cars yet. I'd say that just the Hellcat board had 100K posts, spread over 8 years. We have a LONG way to go........... The Rams have had battery issues since 2021, and even more so the 2025 and 2026. All the same things we've been discussing here.
I believe battery issues could be a factor along with processors and memory chips now integrated into the system. Supply chain issues due to AI boom may have resulted in quality control issues with sensors and the chips programmed to interpretate and act on data received, but we may never know until the dust settles next year. Similar to desktop PCs, I would like to see them replace the AUX battery with a high-end power supply to deliver consistent 12 volt pure sine wave power to the fuse boxes and relays. As we get less analog and more digital/software driven, replacing the battery with a power supply makes sense to me.
Maybe if Dodge discontinues the S/S feature they can get rid of the aux 12 volt battery and maybe eliminate some problems. RJD
Only fix would be to put in a reliable 12 volt battery. Don't know who they bought the trash battery's from but try a new source. RJD
I doubt the AWD issues are battery voltage related. My 11 AWD would get random issues usually at the transition temps where it connects and disconnects. The problem is the mechanicals and the actuator are quite exposed to road crap and temp variations that make the mechanical side of them flaky. I get the AWD errors quote often and predictable. The 11 system is RWD by default until 4C then it defaults to being engaged below that temp. Once it's cold out the mechanism doesn't ever have to disengage so it never has an issue. In the summer it is mostly disengaged so mostly RWD and it lets a fair bit of slip happen before engagement. Then it's a gamble if it mechanically will be able to engage in the situation (wheel speeds, torque, coupler alignments, lubricant, dirt and crap in the seals etc). A common time is also when slowing down and gear changes where tire size, weight transfer, tire pressure, turning or straight and all those factors might make the computer think they're is slip to control but also make the coupler engagement difficult and random. Both have to work and everything literally has to line up just perfect to work and periodically just doesn't. I was hoping the 26+ system was engaged by default rather than disengaged by default so it will be less of an issue and also not require cutting engine power on slip to engage and waste time. So far it feels like it's always engaged and the most unreliable part (axle disconnects) should be more reliable now. I doubt the AWD errors are battery voltage related overall. I bet on mechanical. The actuators can't fix a bad axle disconnect coupler that needs replaced.
I'm sure the dealer will eventually figure out what is upsetting things and it'll be solid once fixed.
Dart
