I use Shell 93. No idea if it's considered good or bad.
Oh, that is WAY good!
Got mine back yesterday after a 4 week stay resulting in replacing the ICM module and MAP sensor this time (previously both Upstream and Downstream O2 sensors replaced). TSB 18-022-26 is now Rev F dated October 3rd. This revision appears to cover a whole host of PCM updates with DTC symptoms including O2 sensors, Downstream Fuel Trim, Wheel Speed, Control Module Communication, Active Exhaust, and even Launch Control Feature improvements. Will do more testing next week after the hurricane passes but hopefully my CEL issues have been corrected.Side question. Do you use good, fresh Top Tier gas? I've been researching this lately and there is some bad stuff out there.
I got the same revision F applied to my car this week. No engine light so far!Got mine back yesterday after a 4 week stay resulting in replacing the ICM module and MAP sensor this time (previously both Upstream and Downstream O2 sensors replaced). TSB 18-022-26 is now Rev F dated October 3rd. This revision appears to cover a whole host of PCM updates with DTC symptoms including O2 sensors, Downstream Fuel Trim, Wheel Speed, Control Module Communication, Active Exhaust, and even Launch Control Feature improvements. Will do more testing next week after the hurricane passes but hopefully my CEL issues have been corrected.
There won't be a notice sent out. You'll only get the update if you bring it in with an engine light on, etc.So far no notice to bring im for up dates later RJD
Ok thanks Later RJDThere won't be a notice sent out. You'll only get the update if you bring it in with an engine light on, etc.
Man, that sucks. Do you happen to know what fault code you had before the update?Got the same update last week , over the weekend light came back on . back to the dealership tomorrow
I had P2096. Is P2099 a 'too rich' fault code??I've had the same code every time P2099
If they put out a TSB on 10/3 I've never got and dealer has not said any thing.Later RJD
Have not heard that. I would think it would apply no matter what. Later RJDThat's for cars that have problems.
I've explained it on here before, TSBs are not offered. You have to have the specific problem that they solve. Unless you're good friends with someone at the dealership, they won't just do TSBs on your car.Have not heard that. I would think it would apply no matter what. Later RJD
TSB 18-022-26 REV F appears to be more comprehensive than the previous REV E. Attached is what I received last week when I finally got my car back. Good luck and hopefully this revision helps solve your issues too. My correction also included replacing the ICM module along with the MAP sensor.Haven't gotten my car back yet but talked to the service manager today. said they had to flash pcm with another update , just 10 days ago it was there getting pcm flashed for the same reason and they have already came up with new flash? still getting a new problem looked at can't lock the car because alarm continues to keep going off. p2099 is bank 2 down stream o2s reading lean causing the system to dump huge amounts of fuel down bank 2 to try and cure the lean
