Check engine light again.
cyrinfl161
Crestview, FL.
About two weeks ago the check engine light came on again, took it to dealership and it was same fuel trim code. They ordered an O2 sensor for it. The day the part came in the light went out and has been off for the last couple of days. Would you still get the sensor replaced? Thanks for your input!!
I think I would go ahead and replace it as its a warranty item no cost to you and hopefully you will not have the engine light issue again. Later RJD
Nope, I'd leave it. I'm sure that they'll keep the part for a while. If a code gets set off, it takes a few cycles to reset it. Was the error code stored when you took it in?
I’m not sure if it was. The light was off for a day or so when I left dealership then came back on. The light has been off since Tuesday afternoon.
I would then replace the part that was originally the cause of check engine light, unless a different code comes up. Later RJD
Been dealing with a parallel issue since May when they inspected power and ground to sensor and replaced downstream O2 sensor. Two weeks later, Check Engine for P2096-00 (Pending) and P2097-00 (Active) was recorded. Downstream fuel trim data not available to Dealership so STAR called a TA to assist. After two weeks in shop, they flashed with a May TSB update and cleared codes. All good until July when check engine light again for P2097-00 Downstream Rich. Light cleared itself on day of service appointment, so they logged the event for the record. August 10th, Check Engine light again for P2097-00. TSB 18-022-26 REV. E was released so they reprogramed modules per TSB. This week Check Engine again with P2097-00 so will be back at Dealership on the 1st when they hope to get STAR to send a TA again because fuel trim data is still not available to the Dealership for diagnosis. I now wonder if like in the beginning, power and ground to the sensor may be an issue. Heat index down here has been 105+, these engines run hot by themselves, and even a small fluctuation in voltage to sensors may trip the event. Will see what they say and find next week as I am now experiencing my 6th Check Engine event over the last 3.5 months.
Was your car ordered or off a lot?
While there have them do an OTA update to see if that will fix your app. Later RJD
My paperwork only showed the before and after PCM calibration codes, the 6871627AN showed up on my car before I had the oil changed in July and they updated the power hatch module., it was re-flashed by the dealer before delivery. I had the P2097 and P2099 codes and the CEL was lit when I arrived!! kept going on and off on it's own. I got flashed to 6871627AO and they re-flashed the Uconnect safety recall. NO light yet, took a week or so last time after they simply reset the PCM to come back.
Code reader before the reader adds a C at the end There was another ECM ID listed that comes back as the part number for the ignition module which is a separate physical part.
Code Reader After
I just found another search that stated when there is an update avail, it will ask if we want it or not now?
The update I got yesterday apparently wasn't available a month ago. These could be VIN specific of course, my car was about 4 months into the production run.
Also those who still have the secret drag/track modes are trying to avoid any updates, but if the car won't run or keeps shutting down, something has to give. I even made passes at the dragstrip with the light on and it shut off sometime in the middle of the session.
This happened to me shortly after purchase. Dealer ordered the sensors. Took a while to get and they gave me a loaner RT 4 door. A week later they called and said they did not need to replace sensors and said it just needed a flash update. It fixed the issue, but that’s when I lost my track and drag modes… I know many say we were not supposed to have these modes, but these modes are a reason many may have purchased their vehicles. These modes did change the tone of the car, so they were actually functional. Dodge needs to bring them back in my opinion!
If they did bring it back it would be an option most likely. I for one really do not need as I have no intentions of racing. later RJD
I don’t think the dealers knew either. They demonstrated the modes before I purchased so it doesn’t make a lot of sense. I don’t race, but it seemed to change performance and the sound for sure! Taking something away like that after a purchase is simply not right!
I did try the track mode before they updated software and it did change it but I’m happy to have sport mode. Just wish I would’ve tried the drag mode…..
