How Do You Guys Keep Rainwater From Pouring Into Your Trunk?
Experienced the water pooling for the 1st time, rained while in store. When the deck lid fully opened the water poured forward and off the sides and onto the rear quarter panels to the ground. No water went into the trunk, some did drip into the drain channels outside the rubber seal.
If lid is not fully opened I can see how its possible water could run into the trunk or if parked on a side slope.
I don't think it matters as to the opening height as mine is adjusted to a lower setting and I don't have any issues with the rain water. RJD
I checked mine in the rain, and after a car wash. Unless there is also a side breeze it isn't bad. Yes, when the water runs off the sides of the hatch (I assume mainly from the spoiler) it will hit the side seal of the trunk and some does go in. But it really isn't much unless it was pouring down, then water is coming in anyway.
Yeah this is how it typically works for me-- but very rarely it decides to flow just the wrong way or something and splatter everywhere in the trunk. It's strange!
Mine just pours in the trunk every time I open it when it’s raining. I don’t have the plus, I can’t set heights and it’s all manual which honestly is kind of a cheap thing to do.
You’d think cars at this point would have a button for a trunk or hatch especially one that large.
Thank you @aceinspp for redirecting me
Your welcome. Your car should have the power hatch. You may not have overhead counsel option but you go to the rear of car and look below tail lights just a little off center to the left and there is a little black button that you push to open hatch. As mentioned you can now pull down the hatch to a desired height. You should see a power button in the trunk area to your left just below where the hatch will close .RJD
