Interior rattles, squeaks and unwanted noise thread.
Let this be the definitive rattles find and fix thread.
First up all these grab handles have an internal rattle for some reason. I was going to put felt or foam been the handle and the mounting plastic but realized now that it's inside the handles themselves. Holding my hands on them while driving makes them quiet. Need to open them up to find a way to eliminate the rattle.
PS: Videos coming, the web site isn't working...
Seatbelt B pillar covers and height adjusters for seatbelt. Shim some foam up there or tape backed foam. That thing rattles subtly going down the road in spite of all the play and hard plastic noise in my video.
PS: Videos coming, the web site isn't working....
Under the driver dash there is all of one push pin clip holding up the front edge of some felt and nothing else. There's a hole in the very middle like there should be a pushpin there but the plastic tab behind it has no hole to push into hence no clip either. Mine is already a bit quieter as I wedged (double sided tape ) a GPS device into there (part of my day job development). This panel flopped around an touches everything intermittently so likely rattles going down the road. The plastic above this is also quite free floating and floppy so I'll get back under that to see about taping things up so they aren't contributing to rattles. The hood latch also could use a foam since it's quite hard and loos fitting little contraptions likely to rattle.
My complaint sounds like my back seat on the right side is not fully attached...it rattles. I had a passenger say it sounded more like coming from the top of the seat belt area or where you take the seat down from area. Idk but it is so so ANNOYING
Atleast u have seat belt height adjusters, that's one thing I wish I had. I guess because the seats I have . they have that little strap with a button to put the belt in . which i use because that just seems like the strap would eventually rip off
The seat belt strap has been a complaint on the EVs how ever there designed a replacement which sees to work. I just do not use the strap as it made it hard to move the seat belt. RJD
