Performance pages and non plus Scat Pack
Ted20
17 day(s)
17 day(s)
Tennessee
Apparently there aren't any. Google said it had them but I can't find the app. This video shows how to access them but there is no such page available on mine at 3:10 I love the car but that is a disappointment.
I'm not certain but I do think performance pages are a Scat Pack thing and not a Plus thing so you should have them. Sounds like you need a convo with your dealer.
Have you tried connecting the car to your WiFi under the "software updates" option in the settings? Maybe it will update and fix something overnight, but I doubt it.
You should be able to get to perf pages either through the vehicle tab how he shows in the video, or through the apps tab. Maybe it will be there for you?
Edit: Are they maybe just locked until 500 miles? I know launch control is.
Is your Dodge an RT? Later RJD
It should be on the Scat Plus it is an up grade. I have the performance pages. The build data shows it is available on your car Later RJD
I have the scat pack six pack non plus. I have no performance app in my apps. I've hit 500 miles and can now launch it. I wanted the performance pages to see the 0 to 60. I downloaded a few drag timing apps to my iphone. Hope they work. I will hit the dealership on Monday.
You should have the performance page. I looked it up and was listed on your car. You may have to tap the middle button on the steering wheel a couple of times as the first two taps did not bring it so I did again and it came up. Later RJD
  • Like
Reactions: Ted
Did that and nada.... All I get are drive modes and launch control
Is this what you're talking about ? I still didn't see performance pages.
Yes but you have to be in sport mode I beleive to find performance page i know I found it by playing with the settings. i get time I'll go back to car and see ow I did it. later RJD
  • Like
Reactions: Ted
Performance pages is in the apps menu, don’t have a button like my 16 Road and track. It’s also elsewhere I’ve just remembered to make it a favorite app
Yeah you shouldn't need to jump through any of these hoops. Check if it's in your full apps list, if it's not, maybe see if you can get it through the app store in the car for free, if neither of those, your dealer's maintenance department owes you some performance pages.
Either that, or it's not actually a Scat Pack and the dealer told you it was-- then they owe you a lot more :LOL:
  • Like
Reactions: Ted
I'd say if he looked at the window sticker it would have said Scat pack. Yes it took me away to find the performance page and yep its a trick. Later RJD
Well, well well, lookey here.... a computer glitch so they say. Went to the dealer's, 3 people trolled through the pages and none to be found. The manager googled this up but it didn't work. Waiting for him to call me back as far as the next step. Any suggestions? It was there when I picked it up but somehow vanished . I reset the Uconnect but no change.
https://www.google.com/search?udm=50&sourceid=chrome&ccb=1&q=where+is+the+performance+pages+located+in+a+2026+charger+scatoack+gas+engine&mtid=YkBNaprUMs_Tp84P1YLm-As&smstk=ChhYL1NWYWhpQXpncTBWcnQ2TEg0VXhwZz0QARgA&smstidx=0&csuir=1&aep=34&kgs=cfd92f9b354c02e4&shem=asdpe,epsd1,rimspwouohc&shndl=37&shmd=H4sIAAAAAAAA_3WOMU5DMRBECRVKg0RJtUqJxHeSIgXiCNzB2tjLepXvtbU2-inT50I5Q07FjwQVohvN6M3M8ny__JgSGYE06Imgkn0Wy6hh1sjUYCwBO0UQBYTteruDkNCYDNocFAwHYGxAyqL0_J56r-3NuWmaBm4du4QhlOwaoYX0Wq3k4lCyb3ML-Z6-8l5RxqEqr55-aS6FRxpQ3Mvd8fR4Wlwergv_X7fk21O3N9Qoyj80ezaMQtrd5vjH8zOvES36zW4d623-G5MaidMOAQAA&shmds=v1_ARwrE21Pm1aNZGT9wogoz_Dn1l1LciCmpaeWvjb5XfnO4NTNoQ&source=sh/x/aim/m1/3&cru=1&cs=0&hl=en-US&biw=1097.1429443359375&bih=547.4285888671875
If the Performance Pages are completely missing from your 12.3-inch Uconnect 5 touchscreen, it is usually caused by an app sync lag or a temporary software glitch in the infotainment system. [1]
How to Restore the Missing Pages
Try these troubleshooting steps in order to force the system to reload the Performance Pages:
  • Perform a Soft Reset: Turn the vehicle to the RUN position but do not start the engine. Press and hold down the Volume knob and the Tune knob simultaneously for 10 to 20 seconds. The screen will flash black and reboot, forcing the system to re-inventory its apps. [1, 2]
    • Let the System Sleep: Turn off the car, open and close the driver’s door to cut accessory power, and lock it. Walk away for 15 minutes. This triggers a full module sleep cycle, which frequently clears Uconnect 5 software bugs and restores missing performance icons upon startup.
    • Verify Over-The-Air (OTA) Updates: Go to your screen's Settings menu and check for pending software updates. Because the 2026 Charger Sixpack utilizes an updated digital platform, a missing app can sometimes mean an initial dealer or over-the-air activation update is still pending. [1]
  • Where They Will Reappear
    Once the system reloads, you can find them using two methods:
      1. The Vehicle Tab: Tap Vehicle on the main Uconnect bottom menu bar. Look for the Performance Pages icon or check under the Apps menu tab if it is not pinned to the main page. [1, 2]
      2. The Steering Wheel Button: You can also quickly access your performance layouts and drive modes directly via the quick-access buttons mounted on your flat-top steering wheel. [1, 2]
      If the soft reset does not bring the pages back, did your car recently receive a software update, or are you noticing any other apps (like Line Lock or Donut Mode) missing from the screen? [1, 2]
      __________________________________________________
      Above it says "Perform a Soft Reset: Turn the vehicle to the RUN position but do not start the engine."It only says run on the dash when the motor is running. But I reset it with and without the engine on but nada. 😱
Ted
try this.. go to vehicle setting on main screen left side. touch home then go to vehicle setting bottom page the look at the top of your screen and you should see dashboard touch it and will bring up you performance pages. I was at dealer today and brought up the performance page on a non plus scat pack. Later RJD
Will have to go to the dealer and get the Uconnect re-flashed. Apparently when I discontinued the 3 free months of WiFi, the pages went with it.
The non six pack plus was on there lot and not sold yet so I don't think this has any thing to do with the 3 months of wifi as they are not turned on till the car sells. Did you try what I suggested? Later RJD
