Good place
Sounds simple and no need to reply “I take mine to dealer” because some of us prefer to make sure we put in quality oil/filters on our schedule.
There are some nuances if you’ve done your own on other cars and even previous gen.
First, the access is much farther back with a little door (no need to remove the whole covers). The door is hinged and took a little finagling to get out- probably the longest part since wasn’t forcing it.
Drain is straight down- no surprise missing the pan! The filter is horizontal and a little tighter than previous gen to get off. I did not swap filter since only 500 miles and the factory uses a gorilla to put these on. I have always used K&N filters with a 1” nut on bottom, which makes removal super easy. Limited space here, so plan accordingly- see photos.
Of note is plenty of sparkly stuff and some sizable pieces on oil from break in- see photos. Also definitely dark- so I would NOT run this to 10k or anything. I plan to do again at about 3k miles with filter. This drain is going to Blackstone along with subsequent for analysis and proof for warranty that I did timely changes
Motor Oil Geek and others recommend multiple changes in first 10k miles. I used 5W-20 Restore & Protect and plan to continue with that.
I’ll post the analysis when I get it back.
Also- there is an oil level reset procedure, but given a little time and oil temp on flat ground, it resets automatically. Initially when I restarted the engine a “Max Oil Level Exceeded”’message came up, but that went away in about a minute and it is setting at just touching MAX with 7 qts in leaving old filter. I guessed the filter probably had 1/2 qt and fill capacity is 7.5 qts- so next time with filter change, I’ll just put 7 again and see where it sets. Factory fill on mine and others seems to be about 3/4 to max.
Hope this helps others!
Started looking into it after I bought my ZR2.. Seems to be a crankshaft alignment issue..Speaking of oil, anyone been following the GM L87 6.2 engine mess????????
