Rear wheel drive mode?
kammrk1
Florida
I have a 2026 Sixpack scatpac, I have only 200 miles on it...when I go to drive modes and in sport mode I can select RWD, I read somewhere the car actually has to have 500 miles on it to be placed in RWD? does the car actually have to have 500 Miles on it or am I actually able to place it in RWD as noted.
The 500 mile mark is for launch control and line lock. Not sure if it's supposed to prevent RWD, but if you can use it then I guess it's allowed. Just take it easy until you hit 500
I researched the threads here and Ares is correct. I see your new so maybe doing something wrong? So, you select RWD and it doesn't work or what?
I select RWD in drive mode "sport" I presume it goes into RWD...I read somewhere needs to have 500 miles on it? but as stated above that is only for placing the car in launch control and line lock.
Yes correct for launch control and line lock. You should be able to select RWD should show you it has been selected if in sport mod. Later RJD
