https://www.toptiergas.com/ You can use their site or app. The manual specifically calls out using Top Tier Certified as recommended… so probably even more important if going to run 91 in lieu of 93… the manual says 91 is the minimum for HO version, but my SO Wagoneer only allows for 93 so that’s interesting…
A quick list of common stations generated from AI:
Most Widely Available
• Shell — nitrogen-enriched formula that cleans and prevents engine deposits
• Chevron — one of the most recognized TOP TIER brands nationwide
• Exxon / Mobil — uses “Mobil Synergy,” a blend of 9 additives including detergents, a friction modifier, and a corrosion inhibitor
• Phillips 66
• Valero
• Sinclair — 1,300+ locations across the U.S.
• Sunoco
Best Value
• Costco (Kirkland Signature gas) — TOP TIER certified and typically up to 21 cents per gallon cheaper than competitors, though membership is required
