- Joined
- Oct 13, 2025
- Messages
- 707
- Media
- 17
- Reaction score
- 325
- Last login streak
- 41 day(s)
- Max login streak
- 43 day(s)
- Location
- Racine, WI
Was it this one I posted a few days ago???After replacing the downstream O2 sensor to no avail, yesterday the upstream O2 sensor was replaced and when the technician was reprogramming the PCM, he found a just released update to flash the module with. Apparently, this update to address these check engine lights has been in the works and now available to dealerships. Will continue to monitor things but been told this new update should take care of things once and for all. Thanks to all who provided support and guidance during this 4-week ordeal and look forward to finally being able to drive with confidence this new Charger Scat Pack Plus with the Sixpack engine.
Technical
The 2026 Dodge Charger is affected by a Technical Service Bulletin (TSB) that involves inspecting and possibly reprogramming the Transmission Control Module (TCM) with the latest available software. This TSB addresses false Malfunction Indicator Lamp (MIL) illumination and fuel trim DTCs P2096, P2097, P2098, P2099, and P068A. The TSB applies to 2026 Dodge Charger (LB) vehicles equipped with the 3.0L Twin Turbo Sixpack HO engine built on or before March 09, 2026. Authorized technicians will use the wiTECH diagnostic tool to inspect the current TCM software version and reprogram it if necessary.dot.report
For more information on TSBs and to check for any outstanding issues, you can visit the official Dodge Technical Service Bulletins page or contact your local Dodge dealer.
