Was provided a Jeep SUV as a loaner. Not as exciting as the Charger but gets the job done. Received an update on my persistent check engine and performance issues earlier this morning. Related to Fuel/Trim data coming from O2 sensors. Doge tech onsite was able to narrow it down but even his equipment/software was not able to get detail data from the O2 sensors to fully diagnose and confirm. Code P0172 implied Downstream O2 sensor that was replaced but did not fully resolve issue. He mentioned seeing something similar in that it was masking a problem with the Upstream O2 sensor sending fuel/trim data to the PCM. Ordered an Upstream O2 sensor but current delivery estimate is Tuesday, 5/26, after the holiday weekend. Note: This recap is from verbal communication over the phone and not officially documented on the service ticket. From what I have been able to read related to Fuel Trim and MAF sensors sending unrealistic data (negative g/S) to PCM control modules from prior years, seems reasonable and hopefully, a correct resolution to my check engine light issues. Once corrected, I have a very good fried at a Pensacola shop with a full Dyno setup to test and record detail data on this Sixpack engine.
